ExoniX »
https://forums.nicoclub.com/exonix-u265.html
Sat Jun 14, 2003 12:47 pm
Well heres the set up im gonna be running.
Garrett T3 .63 Turbo (have)JGS or UH manifold im not sure yet, Maybe someone can help me ? This is one of the last parts im getting.370 CC's (have)Deltagate 40mm Im not sure if its the racegate or not (have)Starion FMIC with 2.25" end tanks (have)S-AFC (not yet)All Intercooler piping and downpipe will be custom, Maybe i can use a SR20 Downpipe ? Any info ?
Im gonna be using brackets to move the Radiator slightly back (like the UH car's) and the IC will be mounted where the Rad used to sit. Only problem ive run into so far is trying to figure out where the bottom mounts will go for the rad, not a real big deal though..
Another concern, Oilpan, How do i get it out ? What size bit do i use to drill it ?
On to engine wise things now..
Vacuum Sources - Where can I get these from ?Carbon Canister - Can i get rid of this ? how about those lines attached to it ? what are they ?Also the 2 hoses that connect to the intake on my intake piping, Do i need these ? Do i have to make pipes for them on my intercooler piping ? I forgot to plug em in once and my car idled for a few secs then sputtered and died..
Who sells the EGR Block off valve or what else can i use to get rid of it.
I know theres alot of questions and I probably forgot a thing or two but im only planning on running 8 psi max on this engine until I build the bottom end.
And how hard is it to hook up the S-AFC ? I might have a shop do it since I really dont like wiring.
