Getting oil pump from stealership, quick question:
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Is there any real difference between the FWD and RWD oil pumps? They have a different part #, but is the only difference in the orientation of the pickup tube? Does it even matter? Ive tried searching and asking in the past, but no one ever gave me an answer.
I am ordering a RWD CA18ET pump unless someone tells me otherwise.
Someone help me out, I am headed to the parts dept. at 3pm today. It is 1:27pm now.
r34 gtr
You guys suck.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
http://www.frsport.com/Genuine....html
according to this the ET is not the same........ but idk
zero_gripS13
Car: soon to be 95 s14 hopefully
i got a ca18de pump... figured thats what everyone uses... hopefully i wont have problems ill have to compare it to my det pump.
themadscientist
The CA18DE and DET pumps, the RWD ones at least, are the same over here.
r34 gtr
Yeah but here they have different part #'s.
This is definitely some information that should be in the FAQ section. I can't recall the number of times Ive asked it and gotten no answer.
BTW those places don't have the pump in stock, and at least Enjuku told me it would be several months to get it. You've got to go to the dealership. My dealership actually had three in stock and it lists for $144.93 NOT $209 or whatever those thieves say it lists for.
domicubarican
Car: 1989 Nissan 240SX hatchback *sold
1993 Nissan 240SX coupe
the one part you get from the ET is the water pump, something to do with the DE pump not letting the pully clear I think.
DE and DET pumps should be the same since it is the same block, but it never hurts to check...dono could be wrong
zero_gripS13
nissan fast part number for jdm oil pump is 15010-35F00
everything nissan says the part number is replaced with
15010-35f01 and its for ca18de/ca16de..
there the same pump.
i got mine from everyhting nissan for 110$ and 19$ shiping.
r34 gtr
$129 total! I got ripped!!
I was under the impression the ET DE and DET blocks were all pretty much the same.
In any rate, I used the 15010-35F01 part # so I should be good to go.
float_6969
The ET pump will probably bolt the the block, but I think the internal design of the ET pump is different than the DE/DET pumps.
The only thing that I've noticed with my FWD DE pump is that the oil pressure has always been lower than what it was supposed to be. I suspect that it's because the DET pumps have a shim in them to increase the pressure for the squirters that the DE's don't have.
This is completely unfounded though and I have nothing to back it up with.
What would be AWESOME is if you got the FWD DE pump and the RWD DET pump side by side and took pics of them taken apart.
zero_gripS13
i got a det pump lol i could take apart. i hope i dont get low oil pressure like i said the part number is the same.. ima check fast on a ca16de fwd and see if the part number is the same.
fast list same part number for fwd ca18.. so pumps should be same regardless no internal changes or anyhting minus the change in the internal gear.. the old style vs new style.
Modified by zero_gripS13 at 10:06 PM 3/5/2009
r34 gtr
I'll take them apart and post pictures the week after next if you would like. Maybe we can figure out how to transplant the shim.
dash
Car: s13 ca18
thread not too far back showed the difference in the CA18 pumps internally.Crescent design as the older, whereas the rounded contour version is the newer georotor pump. Must be a reason why nissan revised it. Pressure perhaps ?
zero_gripS13
i think thenew design cuts down airation of the oil as it gtoes through the pump.. just speculation.
and since the pat numbers r the same , there should bbe no diffference in pressure det vs de pumps.. adding a ship might be nice lol
