Getting my SR20DET / Videos too
240SXer
Car: 1995 240sx SE (2jz powered)
Hey all...
I'm finally going to be getting an SR20DET. I'm having a shop here in SoCal do the swap for me. This is what i'm gonna get with it:
S13 Blacktop, S14 VLSD, Profec B boost controller Spec II, Greddy Type S bov, Blitz Dual Turbo timer, ACT street clutch, Walbro Fuel pump, Nismo mounts, "Hybrid" FMIC Kit (big), Rocker arm stoppers, 3" down pipe..
Ya.. It's gonna cost a lot. Anyway.. I'm really glad about it, I hope to run around low 14s/high 13s @12psi. That sound about right? Is there anything I need to know about owning a SR powered 240?
I was hanging out with my friend and since I'm getting an SR I raced his Supercharged Mr2 to see the difference. I also got a race with a 91 Mustang GT, I rocked him off the line but he pulled at about 70.
http://www.racingonthestreet.c...0.AVIhttp://www.racingonthestreet.c...2.AVIhttp://www.racingonthestreet.c...h.AVI
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
sounds like what i'm gonna be doing in a month or so
cept i plan on an S14 motor, J30 diff, no rocker arm stoppers but 550 injectors
240SXer
I hear the rocker arm stoppers are well well worth it to prevent destroying the motor from overreving. How mucha re you paying for your setup?
240marcuSX
Car: E34 525i
E46 M3
i think itll be faster than that, my bet is closer to 13.4 or 13.5
240SXer
Wow.. about how much power do you think an S13 SR20DET with ApexDual N1, 3in downpipe, Big front mount intercooler, @12psi would put down? You think i'd run mid 13s? That would sure be nice...
Hellion240sx
Car: 1992 240sx se
how much is that setup costing you? so i can get a guesstiomate of how much to save. thankspeace
240SXer
Around 7k total installed
240SXer
Here are some pictures of the car.. it's still in progress but it should be done soon.
http://www.racingonthestreet.c...tures
nissanrcer240
Car: 90 Nissan 240SX SR20DET
MainEvent212 wrote:sounds like what i'm gonna be doing in a month or so
nah man, you should get the rocker arm stoppers, theyre only like $95, and theyre well worth getting from what i hear
rudee023
Car: '03 Infiniti Q45
240sxer: What shop are you going with? I'm in Socal too and was going with McKinney Motorsports when the time comes. Also, if you know a good place for a "smog check" let me know:D
knowleqe
awww, rudee you beat me to it
Hellion240sx
Car: 1992 240sx se
the videos, gotta love the videos. thank you for 'em also which car are you putting this in the 95 or the 91?
240SXer
I'm putting the SR in the 95. It's my baby. See how I baked that Mustang off the line? My car was detonating and running like crap. I was probably only running mid 16s or so. When they finally passed me at like 80mph they waved and were all impressed with themselves. Like their car was sooo much faster. I'm getting it done at garage works. http://www.garageworksltd.com
240SXer
I'm gonna need a "smog check" next year. I also have expired tags. I've gotta get those soon. Damn..
jdmfreak
Nice.I like the vids.
Turb0wned
thats str8 good luck
240SXer
I got my car back. It's pretty quick. On stock boost (which appears to be reduced because i'm at 2700ft) I ran (on the gtech), 15.14@97mph I'm sure I could have done a lot better but I need to learn how to drive it better. At 8-9psi on the controller I ran a [email protected]. The mph on the gtech seems a little high, but the time seems about right. Now I've gotta get my BF 275/50R15 Goodrich Comp T/A Drag Radials then take it to the track. I'd say the tire is overkill but for anyone that's raced at LACR we all know the track is slippery. Especially when it's cold out.
I also wanted to see if I have a governor... If I do, it's well over 118. I took it down to what should be around 130mph. I could barely stop after that, I never went that fast before. I see why many people get the brake upgrade. With an SR you kinda need it.
I'll have pictures and videos soon (camera is out of battery at the moment).
jdmfreak
Nice.
240SXer
I snapped a couple pictures.. I'll have better ones later, but here are some for now....
240SXer
They're huge.. no time to make smaller.. sorry
240SXer
http://www.racingonthestreet.c...ures/
turboex
240SXer wrote:Wow.. about how much power do you think an S13 SR20DET with ApexDual N1, 3in downpipe, Big front mount intercooler, @12psi would put down? You think i'd run mid 13s? That would sure be nice...
With that same setup in my s13 i ran a 13.5 at just 9psi of boost. I used old *** drag radial. You will be suprised once you run the car.
jdmfreak
What engine do you have?
240SXer
S13 blacktop motor... I'm trying to get the boost right with the controller. I ran 14.4@101mph at 8psi now.. I think once I get my launch down and shift into 4th a bit better i'll run pretty good. The boost kept spiking but I think i've got that all taken care of now.
jdmfreak
No I was talkin about turboex's car. Not a bad run with the sr though.
turboex
I have a sr20det redtop. on my 13.5 run my trap speed was 99mph. My wastegate spring was very limp and the best i could get was 9psi and then the car would drop in boost to about 7psi at 5500rpm. This was also with 1.8 60ft times. That makes a world of diffrence.
240SXer
My S14 is heavier so I doubt i'll be able to do that will. I just want to run in the 13s on pump gas.
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
I know S14's are heavier but I love the clean lines of them :)
