getting fire and fuel? help!!!
fastass
Car: 95 240sx
ok i just put in my ka and i am getting fuel and spark but she wont fire up what could be the problem?
fastass
Car: 95 240sx
any input would be greatly apprechiated.
KC240SR
Car: 92 coupe w/ blacktop SR
we have a search feature for a reason.
fastass
Car: 95 240sx
i did search i have found ppl who have similar problems, but not the same as me. i have searched all night and figured i would post to see if i could recieve some help.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
fuel air spark, you have 2, check the third. Is anything disconnected?
More details are needed.
fastass
Car: 95 240sx
ok well everything is connected and grounded the guy i bought the motor from removed the egr and all that on the back of the motor.. and i am having trouble figuring out where he said put the lines that run into the charcoal can.. but other than that its all together..
fastass
Car: 95 240sx
OutToWinPAHC wrote:fuel air spark, you have 2, check the third. Is anything disconnected?
hey pahc how far are you from watertown ny?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I'm in Philly so however far that is.
fastass
Car: 95 240sx
OutToWinPAHC wrote:I'm in Philly so however far that is.
ah ok lol.. yea do you have any idea what could be the problem im thinking the dizzy is off?
S13_love
You didn't mix up the fuel lines did you? Is the starter good?
Like OutToWinPAHC said, more details are needed.
fastass
Car: 95 240sx
S13_love wrote:You didn't mix up the fuel lines did you? Is the starter good?
i know the fuel lines aent mixed up i made sue to mark them befor i took it out. pretty much what its doing is turning over and popping a bit. and right when i let off trying to start it, it kicks over once. but i think its out of time. just firing at the wrong time maybe?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
are you positive you have spark?
S13_love
Hmmm ok...
Are the spark plug wires in the correct places on the distributor?
Im just throwin some ideas out there.
fastass
Car: 95 240sx
yes they are all in the correct places so i think, its in order from the manual..like i said im going to set my distributor and see how that works. and im absolutely positive im getting fire pulled #1 and put it to a grounding point and had good spark.
kouki munster
Car: 97 base 240
If its popping and kicking your timing is most likley off, search for a fsm and follow the direction on how to set the timing.
fastass
Car: 95 240sx
ok i got her running. but bad mews its idle is about 2 grand any input?
fastass
Car: 95 240sx
now i have it at the idle i want now.. but now when i rev her up it has no power. any input?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Fuel injector, Fuel rail or ring leaks, bad plugs, faulty maf....... check codes now she is running.
fastass
Car: 95 240sx
well it ran fine until i put my exhaust on as soon as i put it on and started it it just didnt have any power.. i think it may just be that my timing is off a tooth.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
02 Sensor? Clogged cat?
fastass
Car: 95 240sx
and i have elminated my egr s***.. is there anything now that needs to be hooked to the charcoal canaster?
fastass
Car: 95 240sx
OutToWinPAHC wrote:02 Sensor? Clogged cat?
no cat.
fastass
Car: 95 240sx
i know all i have vaccum wise is brake booster and the one that goes from the fuel rail to the mani.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
CODES!
fastass
Car: 95 240sx
ill have to check..
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
LOL This thread is hilarious... You are one tough guy to work with.. I have to say.. PAHC has got some definite people tolerances...
fastass
Car: 95 240sx
PyR0NiAk wrote:LOL This thread is hilarious... You are one tough guy to work with.. I have to say.. PAHC has got some definite people tolerances...
and how is that?
PyR0NiAk
fastass wrote:
and how is that?
Let's see... You started by giving minimal info. Then, he tells you to check codes and you keep digging for more answers instead of just checking the codes. Your car needs 3 things to run. Fuel, Spark, Compression all at the same time. If you have fuel, spark, and compression, something's out of time. When you installed the motor, did you set the timing, or did you just leave it how it was?
fastass
Car: 95 240sx
yes i did set the time but i think im one notch off.. that would cause it to have high idle right? and with the exhaust on, causing back pressure now it has no power. timing right? bc i have went trough everything else and it all seems to be fine.
PyR0NiAk
I would def. check that timing again. Takes like 15-20 minutes at most.
