jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Tue Dec 27, 2005 8:40 am
either something factory or aftermarket, either way its not needed. vacuum is real simple on this motor, you can find nice diagrams if you search the CA board,but basically, all you need to hook up is the
fpr / butterfly - both of these should be t'd off of the smaller nipple on the back of the manifold (facing firewall)
wastegate - nipple on turbo
brakebooster - use the larger nipple, also located on the back of the intake manifold facing the firewall
boost gauge (optional) - use the nipple right behind throttle body pointing towards the passenger ( on lhd car) side fender.
