Getting better mileage
Offshore1
Car: 2008 Versa SL Hatchback
I was really disappointed w/ the mileage at first on my V.The last tank I got 32.X MPG and today I filled up and got 33.019 MPG!I drive about 80% highway and the rest is city.
The first tank really threw me for a loop cause it was like 23 mpg. I guess now that I have more miles (about 1300) on the car, it is getting broken in.
I can live w/ 32 - 33 MPG on a automatic!! Now if only the steeering wheel would telescope!
Rand0m0sityxX
Car: 2015 Nissan Quest S
2018 Nissan Versa S
yeah your first few tanks wont be good..
It about 1500 when it really starts breaking in, i think.. I know thats when mine did..
fjwagner
Car: 2008 Nissan Versa S et al
Offshore1 wrote:33.019 MPG!
.019!!!! Now that is precise.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
what do you have to say about this? this is the best i have ever gotten... i dont know what it is, maybe the cold air intake or the combonation of the intake + i just switched to 89 octane.... what do you guys think? I will let you guys know the total miles of this tank... with a pic of course...
frankoV
Car: 2008 SL Sedan, Magnetic Grey, CVT
I'm usually about 155mi (250 or so km) when I hit that spot . . . and it's steadily downhill from there -- 100 km (60 mi) or so each "quarter" [why didn't tey divide into actual quaters?].
But indeed . . . I'm curious!
superskunk
now im really curious to see what this tank is going to be... i just had my engine flushed this morning and full synthetic oil change with synthetic oil filter... so im hoping that i will see 400 miles on this tank... hopefully!
Scuba Steve
Car: 2007 Nissa Versa 1.8SL Technology Pakage 6 Speed, Black
superskunk wrote:now im really curious to see what this tank is going to be... i just had my engine flushed this morning and full synthetic oil change with synthetic oil filter... so im hoping that i will see 400 miles on this tank... hopefully!
I bet you'll be lucky to get 330 miles per tank! Let us know!!
fjwagner
What is a synthetic oil filter???
Our lubes guys at ExxonMobil tell me that there is an ~ max 2% increase in mileage with synthetic. You will not notice it tank to tank, but it will save you money over the long haul. It is within those three significant digits I was teasing the OP about. Fred
alex_btl
Car: Versa SL HB/QUEST SE
I just found out after 4 fillups, why it is giving less,
Mine is a CVT SL and I always put 89 Octane Ethanol mixed (Cheapest). First tank gave me 26 mpg, my fuel light came in 195 miles and I kept driving till 300 and filled gas, but it was not 13.2 gallons (Full capacity) as the owners manual stated, it was 11.3 gal,so at the rate of 26 mpg I could have easily driven another 60 miles i.e (350).
Second tank gave me 370, I drove the car with the fuel indicator light on, for another 20 more miles with confidence this time.
when I filled my third tank it filled only 12.4 which is approximately 1 gallon less(atleast 20 miles).
So, it should be 390 miles
4th tank, I made sure I filled it all the way up to the neck of the fuel tank( I could able to touch the gas with my fingers)This time it filled 13.4 (Surprise!!!)
This time my fuel indicator light came on, only at 340 miles and I kept driving till 410 before I filled gas(I could have easily driven another 20 miles)
So the technique is, fill gas as much as the tank holds all the way up to the neck (Try 3 or 4 times even after you hear the first tick noise at the pump)and drive it, it would definitely give good milage.(29 ish)
frankoV
mind you, that's kms . . . so just about 225 mi . . . and next time I put the key in the ignition it'll read different.
Scuba Steve
At half tank I usually get 330KM in summer. I have 6spd.
Modified by Scuba Steve at 5:13 PM 9/2/2008
frankoV
gotta admit we'd be wildly happy if that were miles and not fake miles.
brainguyus
Car: '12 Nissan Murano SL
'08 Nissan Versa SL
'67 Lincoln Continental
alex_btl wrote:I just found out after 4 fillups, why it is giving less,
You shouldn't fill to the neck. Overfilling your tank will cause gas to flow into the evaporation recovery system. sooner or later you're going to throw a "check engine soon" light.
alex_btl
Thanks for the advice, I am not a Pro,Next time I make sure I won't fill more than the maximum capacity stated in owners manual.
NISSAN should have tested this maximum capacity, I guess
Rockhound
Car: 2007 Nissan Versa 1.8 SL HB CVT
2008 Mazda3 GT
alex_btl wrote:I just found out after 4 fillups, why it is giving less...So the technique is, fill gas as much as the tank holds all the way up to the neck (Try 3 or 4 times even after you hear the first tick noise at the pump)and drive it, it would definitely give good milage.(29 ish)
I'm confused, are you saying that over-filling the tank is providing better gas mileage? Sure, the more gas in the tank, the farther you'll be able to go prior to filling up, but if you're calculating things right, your miles per gallon should be similar on a half tank to a full tank.
You shouldn't drive till (nearly) empty and divide by the tank's capacity - you should just divide the number of miles driven by the gallons you used. And you should only be filling up to the first click, too.
#1Tango
for me, the best i got out of my tank was 363 miles. but, i was babying the car so much it was ridiculous. i get about 150 miles for half a tank... is that about normal-ish? i wish i got a lil more
alex_btl
For some reason as frankohabs states its downhill after half tank, I really don't know why, so we really can't come to any conclusion with half tank.I get somewhere between 175 or 230 with half tank and then there is a drastic fall.
Ideally 230 at half tank should give 460 full tank (13.2) but thats not the case.
May be I should carry a gallon of fuel with me and drive the car until last drop to see how much exactly it gives
I have never driven over 60 mph since I bought the car 2 months ago.
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
As has been mentioned before, the tank is not symmetrical, so seeing the needle halfway down is not the same as having 6.6 gallons of gas left. It's just an estimate from an analog sensor. I'm sure they could calibrate it and make it more accurate, but we did buy an entry-level vehicle, after all.
