rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Wed Jun 25, 2008 3:11 am
The stock internals are good enough for low boost. Boost of any kind is never safe on any motor of any build. There is always a chance of detonation. Now the APS TT kits advertised (there are two) are great kits, but one of them requires a built motor which is obvious when you look at the power ratings and the price! The one you want for stock, is the less expensive one. I believe its rated at 7.5 psi, which is ok on stock. Some people have claimed 10+ on stock internals(not recommended). I my self am wanting the Turbonetics single turbo set-up. Supplies 8.5 psi on stock motor, provides 450+ crank power on stock car. Best over all bang for the buck. MSRP is like $5500 but you can find it easily for $4800. No tuning necessary, reflash instructions included - and you can do it all your self, if you are comfortable with that.
Don't forget to check out the 350z FAQ & General Info thread/library (stuck). Has a lot of info in it and one thread about TT's.....
