xonn »
https://forums.nicoclub.com/xonn-u15899.html
Fri Apr 30, 2004 8:08 am
That's the plan. Change all the fluids. Get the suspension and brakes right and then finally engine and transmission swap. I've been debating with the JIC-Magic entry level coilovers vs, the Tein HAs. The HA is at least more adjustable albeit only on dampening... It might be worth saving a bit more and getting the HEs. I wanna do everything right on this car the first time. Those of you that have aftermarket sway bars, where did you get yours from. I'd like fairly thick ones. I run 24mms on my 2300lb neon that I run on track days so at least that thick or thicker I'm thinking would be ideal for the 240...
