None of those look right ... they do not have the "pointy" part that inserts into the dash to engage with the car starting electronics.
Maybe that's only to open the doors, I'd have to investigate. I've actually never seen what an original key should look like.szhosain wrote:None of those look right ... they do not have the "pointy" part that inserts into the dash to engage with the car starting electronics.
Z
Yes, this is the correct one!DRIPS wrote:here is a good example (and pic ) of the key for our car
http://cgi.ebay.com/ebaymotors...ZWDVW
That looks like the correct one, yes.mindovermatter81 wrote:Ok, so I'm about to do a "buy it now" for this key
http://cgi.ebay.com/ebaymotors...:1120
Yes, and all keyfobs need to be programmed at the same time ... so take all of them to the dealer. Some dealers do this for free, if you are a good customer and have them do other work, etc.mindovermatter81 wrote:from what I understand though, I still would need to go to the dealer to have them program it (which should be about $85..),
That is only necessary if you want the key insert inside the remote to be able to open your doors, trunk, etc. If not, then whatever is in there now (see the picture on the auction - I wonder if that is included in the purchase!) is just for use as the attachment for key-chain.mindovermatter81 wrote:would I also need to buy some kind of blank key from the dealer?
Hmmm ... I am confused by this statement. AFAIK, the key insert that is stuck inside this remote is not used to turn the car on ... it is only for the doors and the trunk. The whole keyfob is inserted into the steering column/dash to start the engine ... unless I have totally misunderstood something above (or about my car!).mindovermatter81 wrote:The key I currently have is just a normal one, that fits in the ignition... Sorry to be redundant, just want to make sure I don't buy this off of Ebay then, am not able to use it for whatever reason..
Yup. I just verified this ... it is also mentioned in the Owner's Manual (page 3-2 and 3-3). The "emergency key" (the insert inside the remote), which is what is inserted in the remote, cannot be used to start the engine, but it can be used to release the steering wheel lock.szhosain wrote:Hmmm ... I am confused by this statement. AFAIK, the key insert that is stuck inside this remote is not used to turn the car on ... it is only for the doors and the trunk. The whole keyfob is inserted into the steering column/dash to start the engine ... unless I have totally misunderstood something above (or about my car!).
Okay ... I have contrary results to others now!szhosain wrote:Interesting! I will have to go see if I can do the same with my "emergency" key that the manual says will NOT work.
Interesting!lfj2025 wrote:I used my "metal" key to start my car!!! Learn something new all the time.
