Getting 240 tomorrow
Derf
Getting my first 240 tomorrw. 92 Hatchback, Manual, What would you suggest me doing to it when I first get it. I want to give it a tune up, oil change etc. How deep of an tune up should I give it (giving I find nothing else wrong with it) I also plan to run some seafoam through it
Axel Grungy
Car: 2001 G20 5spd
CARWASH!!! gotta make that baybee sparkle!!
cant hurt to change everytihng you can, how many miles??
navysnail
spark plugs, wires, dist. cap and rotor (check to see if these have been replaced recently, if they have skip it), fuel filter, air filter, oil and filter change, coolant flush if it looks old, clean throttle body, o2 sensor. transmission and diff fluids if your up to it, but make sure you use the correct type of fluid
check the brakes, replace pads if they need it, things along those lines
MikeMurphy
Car: Guess
240kid wrote:spark plugs, wires, dist. cap and rotor (check to see if these have been replaced recently, if they have skip it), fuel filter, air filter, oil and filter change, coolant flush if it looks old, clean throttle body, o2 sensor. transmission and diff fluids if your up to it, but make sure you use the correct type of fluid
CONGRATS ON THE NEW RIDE!!!
Definitely follow the above recommendations. Grab a Z32 fuel filter and replace the stock one as the Z32 should be cheaper and flows way better. There is no downside! It does fit in the stock bracket if you force it.
The biggest difference I noticed was replacing the transmission fluid.
Derf
I was supprised how good the clutch is on it. Sorry no pics. I work to after dark so I can't get the pics.. I will this weekend if it don;'t rain
