gettin the Ka-t together and had some questions
i need tires
Car: 91 s13 coupe... coming soon
ok so i have figured out a way to pretty much have the same set up turbo wise as a sr... this means mani and mounting of the turbo
so my question is with that said... can i use SR i/c piping since the set up is almost identical?
-Jade
Florida240sx
Yes, you just have to modify it. Maybe a cut here and there and an extra coupler or 2......
briguy
Car: 1995 240 sx se
What type of intercooler are you going to run front or side?
i need tires
i will be running fmic
unless i get a smic for free haha
Florida240sx
Do some research man...Seems everytime I reply to one you make another thread....Piping is piping. Depends on the bends whether it will work for you. I id my friends IC piping out of exhaust pipe from autozone...Cut it to size and then had it welded.....
lrb_2000
Car: '91 Nissan KA-T hatch
and SR front mount and piping kit should fit almost perfect.
i need tires
Florida240sx wrote:Do some research man...Seems everytime I reply to one you make another thread....Piping is piping. Depends on the bends whether it will work for you. I id my friends IC piping out of exhaust pipe from autozone...Cut it to size and then had it welded.....
ive made like two threads in the ka-t... so yea and i usually dont do very well with the searching unless its google.com
