sunnys14 »
https://forums.nicoclub.com/sunnys14-u22904.html
Sat Aug 05, 2006 11:28 pm
i couldnt stay NA for long... after my long break after my incident with bad luck with my built motor, ive decided to get back into the game and boost again. after selling all manifold, turbo and downpipe, probably run a cheap SR setup with a t25 till more $$$ gets back in.
for all of you who didnt know, my oil return line was leaking while i was breaking the built motor while NA. it leaked all over the freeway (i didnt connect my oil pressure light ) which caused the rapid chain reaction of engine failure... the exhaust cam snapped, causing the timing chain to snap causing bent valves, which caused the oil pump to seize, which caused my bearings to fail... the motor shut off while all this happened when i was driving. i do not know how bad the bearings are nor do i know what condition the crankshaft is.
does running a basic SR t25 setup on a built motor with 9:1 wiseco's with ARP head studs, cometic MLS HG, safc2, 480cc inj, msd btm and z32 maf seem like a waste on a turbo setup to u? or should i just wait and save up for a huge turbo setup???
