Gettin a headache!!!
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
Plain and simple, I need help. I am rebuilding my 93 240SX. KA24DE and I'm trying to determine which turbo setup would be the best for it. It's been bored 20 over and I am waiting for the Wiseco pistons and H-Beam rods. Also looking to change cams, lifters and valves. Any suggestions?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Getting a headache eh? Ya tell me about it, look another which part should I buy thread...!!!
My suggestion is to search and you should be spending time in the KAT section.
Nali
Car: Datsun Nissan 280ZX
Headache solved!
ashibah83
Car: 93 SUPA BLACK COUPE
^ HAHAHAHAHA, thats great
OP if you know how to put a motor together(i am assuming that your doing it and not having someone else build it), then..... DO SOME DAMN RESEARCH ON YOUR OWN!!!!!!!!!!!
Black on Gold
There isnt a right and wrong turbo setup.Search NICO and find what has worked for others
S13_love
That depends...
What is the power you are trying to acheive?
What size injectors are you going with?
etc.
baron_harkkonen
ashibah83 wrote:^ HAHAHAHAHA, thats great
i know about what hp the engine will have N/A! I am just now gettin to the turbo, was only askin for advice. yes i AM building the engine, yes i've done the research on the block, had the head port and polished. i've got a degree in automotive technology, and am ASE certified as an engine performance technician. but this goin beyond what a 'normal build' is.
ashibah83
ok, im in the same boat as you, ive got my degree in Auto tech, and 3 ASE certs, if you want some good info check the KA-T section here, and also check out http://www.KA-T.org
ok, first off what type of power are you looking for (with the engine being turbocharged)
second, what are you doing with the car, dd,drift, drag???
third, what is your budget?
fourth, will your car be able to handle the power once its there??? is your suspension in good shape, are your brakes in good condition???
baron_harkkonen
aight, lookin for 350-400 whp, right now just workin on the engine; chassis suspension brakes, transmission, etc., u name it its shot. differential seems to be in good shape. as far as type, dd/drift. as far as my budget? i work in a parts store parttime, no limit on price.
Chris28
Car: 92 s13 KA-T
I had a headache. I took some Tylenol. It worked. I might suggest a nice glass of you favorite non-alcoholic beverage to wash down the Tylenol.
Garrett Super Sixty. JGS Mani. Bingo Bango Bongo.
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
Go with a gt28rs, or if you want to be a little more cool, go gt35r. Thats just my impression from turbo shopping, but Turbo sixe mainly comes down to motor strength, budget, hp expectancy. Good Luck!
baron_harkkonen
thx, i'll look into it.
baron_harkkonen
non-alcholic, riiiight. i'll get on that as soon as the liquor shelf is empty.
