Sorry, Joe. I disagree. Fitting body parts requires a lot of skill. It's not like just matching up the holes and screwing it in. Some times the holes have to be moved so that the bumper tucks under the lights properly.joe603 wrote:It will be significantly less money if you bring in the bumper off the car. If you want to save cash, and you're capable of removing/replacing without screwing it up, do it!
Mine turned out perfect. Just shinier than the old paint (obviously).etschell wrote:its hard to match infiniti paint. good luck.
$350+$110 is still better than $750. Hell $350+$220 is still better than $750.Beancooker wrote:I called a few body shops around here (WA state) and the cheapest to paint a bumper is $350, and that is just for painting. Labor is billed at $110. per *shop* hour.
I didn't call some of the cheaper/cheesy body shops, because I would never take my car to them, since they are known for botching the job.
Isn't paint derived from a byproduct of a barrel of oil?WhiteyClay wrote:dealer charger anything from 400-500$ a piece to paint...+laboryour local body shop will get it for 200-250$...+labor
If they are professional painters and can do an accurate color match, I don't see any reason to blend considering how new the car is. My I30's bumper looked perfect. It was that champagne color.bentrod wrote:I worked in the auto physical damage insurance field for 30 years. I do not have the crash books handy for exact times, but here are some basics:
Remove and replace cover labor 2.5 hoursPaint new cover (if it doesn't need to be stripped & primed) 3.0 hrstwotone for black at bottom 1.5 hrsClearcoat 1.5 hrsBlend paint to match qtr panels 2.0 hrsFlex additive $25.00Paint and material ($30 per paint hr in LA) $240.00Labor at $45/hr $472.50TOTAL $737.50 + tax
The blending to match is optional, but if the car is Platinum, silver or any other high metallic, I would recommend it. If your car is the pearl white or gold, that could be a three stage paint and add another $125. Almost all paints used in collision repair today are water based, not oil. Hope this helps.
