1991240xs »
https://forums.nicoclub.com/1991240xs-u242.html
Wed Apr 30, 2003 8:17 am
1991 SE Paint=Crap Mileage was exempt because the guy before me rolled the odometer back. Power windows(work but a button cover on the left is missing). It's an SE, has the sunroof, interior is ok. I'd probably sell it for 2250. It's got a good 50% tread life left on the tires. Guy before me tried crappy tint on the back(purple and bubbly). Has an aiwa cd deck with 6x9's in the doors and the rear. 10 inch sub off of a kenwood amp..tommoroow I'm going to take out the box and reseal it really good and recarpet the box and board(i'll take pics once it's all clean.I bought the car for 2100 exactly a year ago, put 4 tires on, a brand new clutch, catalytic converter, thermostat, radiator, and replaced some old dry rotted fuel lines, then had to replace the front crank seal because oil was leaking. It would be a good project car, it is by no means perfect but makes a good car to just drive until you swap the engine. Save yourself a few thousand dollars, email me if you want more info~
edit: 2nd gear synchro is crapped out...it will grind if you throw it straight into second gear..it's weird..everyone else's does it into third gear-edit2: I have most of the reciepts from stuff I've done to the car, the tires still have road hazard at pepboys...I bought it for 2100 and I'm pretty sure I have atleast 800 in receipts
