Genesis wheel fit on G35 coupe?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
kenko95
Car: 2000 I30
I found some winter wheels set up on CL but just wanted to see if anybody knew about the fitment. I have a 2006 G35 coupe auto with factory 19". The wheel setup listed is for 2009 Genesis. 225/55-R17 97T Bolt Pattern: 5 x 114. I did some research and it looks like the center bore is 67.1 for the Genesis and G35 is 66.1 so I would just need to purchase hub ring. I'm trying to do much research as possible before making a bid on this set. Thank you in advance for the help.
audtatious
The above is correct, without a hub-centric ring you will probably have a bit of wobble as lug-centric (using the lug nuts to center the wheel) is never perfect. I don't think they sell a 67.1 to 66.1 hub-centric ring either.
kenko95
Car: 2000 I30
Thanks for the info. So the winter set up from the Genesis should fit? I found the hub rings on ebay for 67.1 to 66.1
http://www.ebay.com/itm/4pc-Aluminum-Hu ... 81&vxp=mtr
audtatious
Yes. Offset is 35-40mm which should work as well.
kenko95
Car: 2000 I30
Thanks for the help.
audtatious
Post up pix, be interesting to see what it looks like.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
