Generic question in how to power 10 inch subwoofers...
Post all your Nissan electronics, car audio and stereo questions here!
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
2 (10 inch) woofers50-300W RMS4 ohmssingle voice coils
what wiring configuration and amp (mono,stereo,etc) should I use???
zerepdivad
Car: '90 240sx . '02 Lexus IS300
If you've got 2 of them at 300 rms get a mon amp that puts out 300rms at 2 ohms and wire the subs in parallel. That's if total rms is 300 *150 rms each* If 300 rms each then obviously go get a mono amp that puts out 600 rms at 2 ohms.
amolao
thanks, will do...
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Depends.
If you get an amp that's 1ohm stable, wire the coils in parallel and bridge a 2chan amp.
Or, if you get an amp that's 2ohm stable, either get a mono amp as stated above, or get a 4 chan and bridge each set of 2 channels to each sub.
amolao
But this will only apply to dual coils subs, right ??Im running single coils on the system....
