Beancooker wrote:Phoenix Technologies is okay. Thay make a lot of BIOS...
I really don't want to give you bad info here. If it was me, I would flash the BIOS to the stock BIOS. But if it fails for whatever reason, you very well may be s**t out of luck.
Well I figured that was the best route to take BUT I cant find the OEM Dell bios. Where could I go to DL it?
Beancooker wrote:A safe plan would be to restart the PC, and hit "del" or "F4" or whatever is needed to see the setup menu.
Take note as to the version of BIOS that is currently running. Download that version and save it on a flash drive. That way if for whatever reason the stock BIOS doesn't work, you can revert back to what you know does work, via the flash drive.
Where can I get info on this "Flash drive" you speak of? Or did you just mean any type of save able media?
Beancooker wrote:Why are you reflashing the BIOS anyways?
BECAUSE:
audtatious wrote:You need the BIOS upgrade to support 1GB of RAM.
That and I checked on other forums...
Beancooker wrote:I would try installing the extra memory FIRST, then go to your start button, right click "computer" click "properties" on the drop down menu. Look and see how much RAM you have. If it shows all the memory installed, you don't need to reflash.
That was my first step. I started the NB up and it made 4 beeps, then the hard drive stopped spinning followed by the hard drive running and a constant black screen.So I think it is safe to say I need to reflash to A32
PoorManQ45 wrote:Working for dell I would not recommend updating that bios unless you can easily replace the laptop.
I large jump like that can easily kill the motherboard
Replacing the NB isnt on my list =(I wish it was ::SIGH::
Also can a ram upgrade really mess with the hard where? Is it due to the extra heat?
PoorManQ45 wrote:Depending on the age of the system, if it was before july, 2004 you have lifetime phone support. If it is older then this call into technical support and ask them to walk you through updating the bios.
The official stance is if you are doing something that a dedll representative walks you through doing and it damages any component that it is covered, even on out of warranty systems.
Hmm I will definitly check into that. That sounds like my best bet
Beancooker wrote:Hope this helps. Post up if you have anymore questions. I'll be watching this thread all day tomorrow while at work.
ALSO thank you for your responces Mr. Cooker and Mr. PoorMan
