I only ran +30 to see how my AFR's adjusted during idle trying to get it to 14.7. I know JWT tunes it rich under WOT but not sure during idle or cruising. I don't even know if it's possible to do that. I haven't had a chance to tune it yet so it's set at 0 across the board.
I don't know why my AFR's at idle are so lean. Maybe it's the MAF????
I just ran another little test. This time I recorded the data while the engine was warming up and +30 across the board as it seems I may be lean. Next time I'll run it at 0.
When cold my AFR was 14.7 and gradually increased as it got warmer to 16.5-17 then it dropped. I can't explain why it did this. It wasn't completely warmed up and it did climb back up.
http://okifx.dynu.com:8383/dri...p.jpg
After it was warmed up I reved it up to 2000rpm and 3000rpm holding it for about a minute.I was in the 14.7 - 15.5 for 2000rpm and 14.3 - 14.9 in the 3000rpmhttp://okifx.dynu.com:8383/dri...k.jpg
I then just let off the gas and was around 17.5 - 18.5 and still idling just fine.
I did a couple of revs just for the hell of it. First spike was at 4000rpm and second at 5000rpm then held it at 4000rpm getting 14.5 - 15.5 AFRhttp://okifx.dynu.com:8383/dri...v.jpg
Now this isn't an accurate way of testing but it's all I can do for now. I can't drive around with it yet but it seems that my AFR's are ok except during idle. Maybe that exhaust leak I have is messing around with the reading?
Also something to note. A few weeks ago I took my HKS filter off and the car would barely run. I had to keep it up to 2500rpm just to keep it going. It was popping like it was rich. I'll run a test on that again later but I can't stay out more then 30 minutes until I start to freeze.
Modified by okis14 at 9:45 PM 12/15/2004
Modified by okis14 at 9:50 PM 12/15/2004
