SloMoe »
https://forums.nicoclub.com/slomoe-u5234.html
Thu Feb 17, 2005 3:18 pm
If you want it to run reliably, recirculate your BOV.
The ECU has no idea how much boost you are running the only thing it knows is how much air is entering your engine based on the MAF voltage reading, and the load its under based on the Thottle Position Sensor. It all depends on how much different the levels of boost are that you want to run and your tune. The ECU can compensate to a certain point, but if you want radilcally different levels of boost ie 10psi for daily, and 20+ for racing, its best to go with a standalone that can refrerence boost from a MAP sensor.
