General Questions about SR swap
driftin240
Car: in love with cars
i own a '95 240 with about 68k miles and I decided that by the time i turbo'd the KA it wouldnt even be worth it, so I plan on going SR in the future but I was curious if the engine swap was all that went along with it or if I would have to do suspension mods or anything extra to handle the xtra power...??
the_invisible
Hey hey, I have the a S14 also. Mine is VLSD equipped with no ABS, Canadian SE. I have some brake upgrades and wider tires.
I think if such low mileage, 68k, suspension isn't really mandatory. The stock s14 suspension is already very good. Don't flame me. This is just my personal opinion. maybe some chassis stiffening can do you fine for a little while before you up the boost.
I H8 MYSELF
Captain I H8 NICO says: Maybe not neccessary, but you might want to consider how you will stop all that extra power, NO??
THANKS AGAIN!
quiksilvia
Car: 95 s14 se
do a 3z brake upgrade, tein suspension, and while ur at it get the lsd and upgrade the whole driveline
Tai Mai Shu
Driveline? They are pretty soild on the 240's I wouldnt worry about it unless you are 400+ hp. I would ocncentrate on other stuff.
driftin240
ya I would love to get the 300ZX brakes but they are a lil pricy...first thing is to pay for the engine then I will see how it goes...thanks for the replies
the_invisible
I have brake lines all around, brembo slot/dimple drilled rotors. KVR front and metal at back. Braking is excellent. The 240sx brake system is good enough already. It could have been better if my aged bushings were swapped out with urethane ones. My T/C rods bushing is weak from aging, so changing it would increase braking performance on an already excellent braking car.
driftin240
my brakes are pretty ****ty now they make that awful grinding noise and they dont work as well as they used to
FTRS14.5
Well, why dont you replace them before they do more damage??
