Infinitiguy19 wrote:Are the threads at the end exposed with the nut tightened to spec torque?
As I said earlier, after I pulled the shaft off the center bearing, I hit the threaded end with a raw hammer. Nut was off.
Infinitiguy19 wrote:They make special dies that slip over the bad threads and onto the good threads. You probably use one of those. I saw the product on a show called Gearz. I can't seem to find it now.
This isn't something I can wait to get done, so expensive specialty tools isn't what I'm after, really. But cool nonetheless.
Infinitiguy19 wrote:You could also try cutting the mushroomed part off exposing good threads. Then use a thread file.
One swing is all it took to mushroom it? 3-4 lbs "hammer"?
Can't cut the threads off, the nut end fits barely over the end of the shaft. Also, it's not mushroomed, the threads are compressed; the opposite of stretched threads.
All I really want to know is: Can I take this thing to a machine shop and have them re-cut the threads on the end or will I have to get a new front shaft from the junkyard?
