...And I could use a few tips!
I do have the Repair Manual - and both it and others here indicate that the RIGHT side half-axle must be removed in order to remove the LEFT side.
First, is this definitely true? and Second: Though I do see the tap-a-screwdriver-from-the-right-side-to-remove-the- left-side method in the manual, could someone shed a bit more light on this (Before I get under the car!)?
Where exactly is the access window for this process?
How long a screwdriver is needed for this?
Are there any spline alignment or other gotchas to be aware of before I start all this?
Did everyone use the seal protector tool as indicated, or did we all make one out of lying-around plastic sheeting, as I plan to do?
Many thanks for any help/tips/pointers anyone - who's done this job! - can offer. Lou
