Gen. 1 Rogue - Rear cargo/tonneau cover (pull out)
brickbox
Car: 2011 Nissan Pathfinder 4x4
I am interested in adding the pull out rear cargo/tonneau cover for the cargo area (black color for my car).
The gen.1 covers are quite expensive online costing more than $150. Does anyone know if the covers from the gen.2 Rogues will fit the gen.1 cars?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Little if anything from the 2nd gen will fit the 1st gen Rogue. Well the tire valve stem caps will, but the rear cargo cover will not.
Did you check ebay?
brickbox
Yes I searched eBay and local Craigslist as well - no luck yet.
wyfesROGUE
Car: 2013 Rogue
Hi!
Not sure what gen the Rogue is.
Will the 2014 version fit the 2013?
Thanks!
Reason: Merged with existing thread
Rogue One
2022 Honda Pilot SE
Ok, ALL of this has been discussed before. We have an incredible SEARCH feature on this forum. 2014 & 2015 1st gen Rogues have a badge on the liftgate that says SELECT. 99% of the parts are NOT COMPATIBLE between the two generations, which includes the cargo cover.
This is a 1st generation Rogue:
This is a 2nd generation Rogue:
wyfesROGUE
Car: 2013 Rogue
I did use the search feature, didn't find my answer, thanks.
Are you saying the 2013 was the last year for generation one, with the exception of the 2014/2015 Select?
And, that nothing from the 2014 / 2nd gen retrofits into the 1st gen?
Thanks!
Rogue One
2022 Honda Pilot SE
wyfesROGUE wrote:I did use the search feature, didn't find my answer, thanks.
Really? Search found 1123 matches: cargo
When using the NICO search function, limit your query to one or two words. Topics merged.
YES
At the risk of repeating myself, YES.
LuckySeven
Car: 2008 Nissan Rogue SL AWD fully loaded
Paid 25 bucks today for a black cover as mine went missing with the purchase. Previous owner probably never included it. Also paid 50 bucks for front rear and cargo weather tech mats.
Return to “Rogue Forum”
