Gears poppinig out on the KA
SilGuy
Wussup..i jus bought this 92 240...and the gears pop out at times and feel weird when i'm shifting. The reverse has popped out too. I've searched..and didn't find anything...if u guys know the link to the thread...give it to me please. I'm not familiar w/ the Nissan Transmissions..but i'm assumin they're kind of similar w/ t he hondas that i've rebuilt in the past. new transmission fluids, rebuild transmission? OR can i adjust somethin? Thanx in advance...
bp2ooo
i would have to say rebuild the trans, but outa curiousity did you install a short shifter? try the stock shifter, if you did, i have a friend with a crx that put a ****ty short shifter in it and it would always pop out, put my stock integra shifter in it, and its been fine ever since.
BuudWeizErr
make sure your C ring isn't missing. And do you mind telling us why you decided this needed to be in the SR20 forum?
yellow_jacket
Car: 95 240sx
Usually when the rwd transmission's start popping out of gear it is because the syncros are going. Check the shifter first of course.
These transmissions and shifters are nothing like a honda/acura shifter set up is and the reason why those short shifters create problems is going to be completely different.
SilGuy
BuudWeizErr: Cuz the SR forum is the most active and i figured the KA transmission and the SR have some similarities. I just bought the car 3 days ago from an old dude, it has a stock shifter. I dunno if it has the C-ring or not, but i will check sometime...but im jus tryin to get a general idea of what could cause the problem...thanx
BuudWeizErr
Crap, I thought you meant the shifter was popping out.. nevermind my c ring idea.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
It's time for a transmission rebuild! My friend's mustang did that, and I couldn't stop laughing when it did. It did it under mid-hard acceleration. He would have to always hold the shifter in gear while accelerating. :D Rebuilt the thing and been fine ever since. This sort of thing happens when people don't change the fluid in the transmission often and the syncro's and gears begin to wear badly. A transmission is like a motor, it needs fluid changes too.
Cyberkreig
Car: 1993 Nissan 240SX SR
Similar thing happened on my SR trans. 1st & Reverse are on the same Syncronizer Ring, So if one pops out, they both will. Only choice is to rebuild or replace. Why the hell do they make Transmission parts out of brass anyway?
SilGuy
I'm not gonna rebuild it since i will be gettin a SR w/ trans soon..as soon as i sell my integra. I was jus wondering if anythin minor can be done...but guess not...heheh Thanx!!
ItzGenX
Only thing you can do is hold on to that shifter indefinitely to hold it in gear :(
