ProperQ »
https://forums.nicoclub.com/properq-u35611.html
Sun Jan 08, 2006 1:01 pm
Thought you'd never ask, Just had the transmission serviced about 2,800 miles ago. Also changed the belts, the plugs (wich looked just right, a nice golden brown with no divits or dents) and no telling when they were changed last. Also Oil and filter, and fuel filter, changed most hoses and all the clamps. Replaced fan blade. New brake pads front and back with new rotors in the front. Sealed some cracks in the air intake hose and built a support so it would no longer sagg,(of course cleaned filter and MAF, the right way) that being said the car belonged to two previous owners both of which had the car serviced regularly by the same men, for the most part any way by my good friend and his father (very qualified to say the least) who cared for the car like thier own baby. Now the only problem we ran into was the gasket for the pan didn't fit from the kit we had purchased from Auto Zone, so we cut a new one from a roll I had to purchase from A Zone. Any whoo their was a slight amount of shavings on the magnet and the fluid was well overdue for a change. Our collective opinion is to never flush all the fluid when doing a transmission service, (never ends well for some reason?????) however cleaned the pan and the magnet (those japanese, smart they are) fit the gasket drilled the holes spit shined and mounted fine. Now for the goods we used a Castrol ATF Dextron also B&M Dextron trick shift fluid with Lucas stop leak transmission stuff (an additive I believe) it seems to work wonders for older transmission's. Everything was fine untill last week or so I checked the fluid and it looks good still reddish and smooth no bubbles or inconsistancy smells just right for the time its been in just a slight sent. Measures the same every other day and no leaks so far. I am leaning toward the rear diff since at first I couldnt get the low gears and reverse and now I can't get 3rd and drive. The switch came on a left turn over a bump and the slip light came on. I don't know when the last time it's been changed but I'm sure it's past due. I don't have an FSM and desperatly need one in a hurry, I'd walk 40 Miles to get one tonight. Oh yea no ATF cooler yet but I'f I get this running right it's good as installed.
Modified by ProperQ at 4:57 PM 1/8/2006
