Gears and speeds
mikesr20
My Digital speedometer has not worked since I did my swap....needless to say I need to know about what speeds certain RPMs are in certain gears. if anyone has this info or can give me a roundabout way to figure it I would really appriciate it.Mike
karmakaze
Car: 98 240sx SE
mikesr20 wrote:My Digital speedometer has not worked since I did my swap....needless to say I need to know about what speeds certain RPMs are in certain gears. if anyone has this info or can give me a roundabout way to figure it I would really appriciate it.Mike
http://www.f-body.org/gears/
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Heres the Gear Ratios1st - 3.3212nd - 1.9023rd - 1.3084th - 1.0005th - .759Rear - 4.083
Modified by DrifterProdigy85 at 9:12 PM 2/7/2007
Hudsontec
Car: 1989 240SX w/RB20DET, 1991 S13 SE W/SR20DET
Do you want to sell your non working Digital cluster?
mikesr20
not really. the tach still works, I would rather find out how to make it work with the engine.
DrifterProdigy85
It should work fine unless the Digital Unit itself is bad. I used my SOHC Digital & HUD with my SR swap. If you think its the wiring, Yellow/Green Stripe is the Speed Signal from the ECU.
