T45 »
https://forums.nicoclub.com/t45-u41813.html
Fri Sep 07, 2007 2:33 pm
You could always do what Ellis Autoworks has done and I am doing. Save yourself 500 (beaconsfield ) bucks and weld the front of a Q45 bellhousing to the chosen trans.
The beauty of Nissans is that the distance from where the bolt heads rest on the bellhousings is the same on all transmissions. All that is needed is to cut on that line on both housings, align your trans to engine and tack them together. Keep checking for good clearances and that the shaft is not binding up in the pilot and you're good to go. Not for the inexperienced fab artist though so if you're not handy..... at least the women will find you handsome....or something like that.
