gearbox advice needed
ka-lin
Car: 1989 Nissan 200sx(European version) S13 CA18DET
It's a shame that my first post here (hello, forum! ) is about a technical problem.....
What actually causes the 4th gear to jumps out while decelerating with engine as a break at 4th gear?
When I put 4th gear in, if i press the gas pedal, everything is fine, until I release the gas pedal, and let the car to kill the speed with engine...Only in this case the 4th gear jumps out..
Things I've checked/tryed:
1. Another input shafts - a little bit better, but still not dramatically improvement. 4th gear jumps off while decelerating at high speed.2. Changed direction of coupling sleeve of 3&4 syncho - even worst:annoyed: 3. Tryed another 4th gear selector (pressing it out with a press from old input shaft and put it into another input shaft) - nothing improved.4. Tryed another synchro (baulk) rings, nothing improved.
The synchroniser hub looks fine, all the clearances are fine, all gears, especially the 4th are fine.
Please note that If I put a little bit harder the 4th gear in, the things got a little bit improvement. But not for long.
I'm ouf of ideas. Please, could anyone to help, and give mi direction what can be that, because every day I remove, disasemble, replase something, assembly and mount the gearbox. I've do that probably 15-16 times, until now..
480sx
Car: 1996 Pearl White 240sx
Your 4th gear shifter fork is broken. The part itself is not expencive, the labor can be if you dont do it yourself.
ka-lin
Shifter fork? ?You mean that part that actually moves the coupling sleeve between 3rd and 4nd gear? How can I to determine where is the damage exactly? Thanks, mate
ka-lin
Could be overfilling to be the reason?
