Transmission maintenance history?coolman wrote:I have a 1994 Q45 automatic transmission. When the engine is cold (first 7 mins of driving the car), the transmission hesitates and sometimes do not want to shift from 1st gear to the higher gears. The engine will rev upto 3000rpm and still be on 1st gear. After about 10-15 minutes when the engine is hotter, the car slowly returns to normal operating conditions with the gears shifting normally. I also smell gasoline while sitting in the driver's seat.
My question is what could cause this problem and what should I get my mechanic to replace or fix?
First, you need to download and read the FSM.coolman wrote:- The transmission fluid was probably last change 3-4 years ago.- I do not know what a plenum is and I bought this car used a few back.- I bought this car used and don't recall any transmission maintenance other than changing the fluids.
It runs ok when the car temperature is a normal operating mode, but when called it exhibits these problems that did not exist before.
Many as ATF temperature is stabilized and reduced under demanding operation. Read some of the previous posts, including all by Q45tech. Might be too late for the one you have now. It's not climate, but hills and high speed.coolman wrote:maxnix,
It does not have a ATF cooler. Should I get one of these and what are the benefits?
I got the ATF fluids replaced at JiffyLibe. So, I think it was just a change of fluid only.
1.) So you don't know exactly what was done. Glad that is certain now.coolman wrote:1.) The ATF service done at JiffyLube about 4 years ago is simply a fluid change only, just like a radiator flush. Nothing mechanical was replaced or fixed.
2.) So, I bought Lucas Transmission Fix 24 oz at Wal Mart and added to the Q45.
3.) I will look into the ATF Cooler. I will have to look on how much it will cost for parts and installation.
4.) I also bought a K&N pre-oiled filter that I plan to install. I plan to keep this Q45 for a few more years, so I plan on maintaining it as much as possible.
Not to sound like a jerk, but the steps you posted in the diagnostic are a bit backwards. "AT Check" should show at the beginning of the diagnostic process, anything after that would either be an "OK" display or some sort of code that can be deciphered in the FSM.coolman wrote:Here are the answers to some of the questions.
- I have about 208K miles on the car.- The color of the transmission fluid is reddish pink and is full.- The transmission fluid was probably last change 3-4 years ago.- I do not know what a plenum is and I bought this car used a few back.- I bought this car used and don't recall any transmission maintenance other than changing the fluids.
I performed the self-diagnostic which requires stepping on gas pedal, changing drive to D, 3, 2, then 1 and rotating the trip button counter clockwise. The display only shows "AT Check" and nothing more.
Thanks,
They are really better understood as ATF heat exchangers in that if the ATF is under ~200° F there is no cooling.coolman wrote:The color of the ATF fluids before I added the Lucas Transmission Fix was pink and clean looking.
I did some searching on this forum and someone said the 94-96 Q45 has a radiator with 2 transmission coolers on each end that works pretty good. The other Q45 year models did not have this 2 coolers on each end. My questions is since I have 2 good transmission coolers already built in and just replaced my radiator with original OEM parts a few weeks ago, do I really need an additional ATF cooler? If so, is there a way to use both the already installed 2 trans cooler built into the radiator and the ATF cooler at the same time? I may decide to install a transmission temperature gauge so that I can monitor things.
Yup. You're doing it incorrectly.coolman wrote:Haitian_King,
The Transmission self diagnostic procedures says to turn off engine and set to OFF position with the car keys and then shift to "D". However, in the OFF position, the 1994 Q45 has no DC electricity feeding in which is needed since my car requires depressing the brake pedal while shifting from P to D. There is some electronic lock preventing the shift unless you have the brake pedeal down and this electronic lock does not work in the OFF position when no DC electricity is powering the electronic lock.
Instead, I tried to turn trip reset knob counter clockwise and held it there while starting the engine. The display now says AT Check. I then shifted from P to D while brake pedals are depressed and now display says OK. This procedure I made up seems to work. Can someone verify this?
Also, can someone verify that I still need a ATF Cooler. My brand new OEM radiator already has a transmission cooler built into it. Isn't this sufficient?
Yesterday, I added 2.5 quarts of Mobil 1 ATF Synthetic ($7/quart at Kragen). The trans dip stick now reports it as over filled, but that is ok. My trans shifting and driving is all back to normal. About a few weeks ago, I bought a new OEM radiator assembly from infinitipartsusa.com (it includes the transmission cooler sections too). I think the car repair shop emptied the transmission fluids and either put in cheap grade ATF fluids or did not fill it to the correct levels. I am not blaming the car repair since I did experience these problems before. Probably my fault for not knowing how to correctly measure the ATF fluid levels and not knowing about ATF Additives/Synthetic fluids.
Thanks,
http://www.q45.org/trannycooler.htmlcoolman wrote:The "shift lock" button is permanently pressed downward and will not come back up. So, I think this button is stuck or not working. It doesn't look like a button. It looks more like a piece of plastic plate or something.
Also, I just ordered the B&M 70268 for $50 total from Amazon.com (no tax and I got Amazon Prime for free shipping). I plan on getting a mechanic to install it since I almost never work on cars. If my transmission can last longer with this cooler, than it will be worth it.
Also, my air box which contains the air filter has 1 of the 4 metal clips broken off. I would like to replace it with an Intake Air mod. What kind should I get and how easy is it to mod it myself?
Thanks,
The best "mod" you can make to your air box is to replace the clip or that part of the air box.coolman wrote:Also, my air box which contains the air filter has 1 of the 4 metal clips broken off. I would like to replace it with an Intake Air mod. What kind should I get and how easy is it to mod it myself?
