Gear Shifter
srttmad
Car: G35
I have a 04 Sedan AT. Does your shifter move a little when going over speed bumps? Is this normal or what?
yzarcur
Car: 2004 Infinity G35 Coupe
My guess is because your shifter is attached to your transmission when you go over the bump and because you have flexable movement in your transaxle you will get movement in the shifter. Now it is just a guess, if you feel the movement is accessive then you may have a loose contection and shoule have it checked out. static/icons.html#
