It's okay man, I'd flaunt it too if I had it like that.ozzie! wrote:I tried opening mine, but couldn't find out how, so I left mine alone.......Besides, I have a shift indicator in the gauge cluster.
Sorry Drew, I had to go there....
What doesn't your car have!!!! I love your car. I keep thinking about your A8sozzie! wrote:Besides, I have a shift indicator in the gauge cluster.
what size were the shifter bulbs? Were they T10 (wedge) bulbs?How many were there?DrewQ45 wrote:I got it done today. I pushed through the carpet with a scratch-awl and stuck a phillips head screwdriver through to access the screws. I think this is actually the intended method since there are accomodating holes in the metal for the front screws.
I didn't use LEDs by the way. I went to a local pep boys and found red gel cap bulb covers. Simply removed the blue bulb cover and pushed the red caps onto the bulb. It looks great and the nice thing is, I have lots of these bulbs laying around. So I have a combo of LEDS and bulb covers now. I'll be using bulb covers on the final step...the cluster. I think the bulb covers diffuse the light evenly eliminating bright/shadowy spots. This is why manufacturers use the blue covers in the first place.
To be honest, If I could have found red bulb covers small enough, I never would have bothered with LEDs.
http://www.elcovaforums.com/fo...age=2
It's a single 158 bulb... Same bulb as those backlighting the cluster. I guess 194 would work also.ozzie! wrote:
ZOMG!!! dude, you are so right..... my rear license plate fell off last night. Is there any way I can save my car before it completely disintegrates?speedingminivan wrote:Be careful with this. On some of the cars to make it out of the factory the entire rear suspension, the doorsills and the rear license plate are hooked to the car by way of these 4 screws. Really a shame, some people changing to LED's and the car falls apart...
Time to sit back and enjoy the show.
Unfortunately, no. I'm tired of it anyway since it doesn't have MP3 capability and I don't want to use one of those cassette adapters or FM transmitters.lino wrote:Awesome work Drew! You're almost done. Does your car stereo change colors?
Crack is wack!speedingminivan wrote:Be careful with this. On some of the cars to make it out of the factory the entire rear suspension, the doorsills and the rear license plate are hooked to the car by way of these 4 screws. Really a shame, some people changing to LED's and the car falls apart...
...Drew...
**EDIT**Just took another look... those are not the screws...they're the horizontal screws laying just to the left on the plastic housing. If you extended your arrows past the holes you're currently pointing to, you'd be pointing to them.lino wrote:Is this where the screws are?
