It's not a big job, but on a 10-year-old vehicle, you will need to be careful about the lefthand HVAC vent. That's especially true if you have the tan interior, that plastic seems to embrittle easier than the gray or black. You can find the exploded drawings here on IP-12 and IP-13:
https://www.nicoclub.com/service-manual ... 4%2Fip.pdf
Remove the lefthand end panel 6 and lefthand lower dash 11 first (two M6 screws and a bunch of pawls). Then remove the finisher underneath the vent (2 in the lower drawing) and then the vent itself (not shown). Then tilt the wheel all the way out and down and remove the bezel 8 around the cluster. If memory serves, those attachments are all pawls, no screws. Then there are 3 phillips screws holding the cluster in. My apologies in advance if I missed anything, we don't see a whole lot of Quests and it's been awhile since I had a Quest cluster out.
