very nice! how hard is it to swap the xterra front diff? is it just the guts?Tulsa_S-13 wrote:Maybe this will help
All Nissan differentials should have a stamp on the ring gear identifying the ratio.
The J30 differential is 3.916:1
The stock 240sx final drive is 4.083636:1
Since you're making your car strictly for drag racing than I'm guessing you'll want a shorter gear ratio than your current J30 differential.
Luckily as an S-chassis' owner you have several cheap VLSD options to go with. The 180sx, HCR32 [GTS-T Skyline], J30, 300zx, Xterra front differential.
I'm assuming you're looking for a gearing shorter than the stock 4.08:1 FD. In this case, the HCR32 VLSD has a ratio of 4.36:1. I recently purchased one from JHOT Imports for $150! Talk about cheap! Of course, the output flanges differ from the stock 6-bolt flanges. So when needing the 5-bolt flanged axles you can source out a set from the '92-'94 J30.
You'll likely find several 5-bolt 180sx VLSDs floating around for sale. Only the 89-90 CA18DET equipped 180sx's had the 4.36:1 final drive, the other years have a final drive of I believe 4.11:1.
If you're wanting something REALLY short you can use the internals of the front differential from a 2001ish Xterra SE, which have a ratio of somewhere near 4.80:1. You'd have to ask NICO member Codyace more about this setup, as I am not too familiar with it.
Be sure to check out KA24DEvelopment's writeup for more information:
http://www.ka24development.com/vlsd.html
I used a 2001 SE Xterra for my parts. Got most info from a thread on F/ADrifterProdigy85 wrote:Xterra had 4.636 or 4.90. I cant remember what was in what model years though.
SR Gear Ratios1st - 3.3212nd - 1.9023rd - 1.3084th - 1.05th - .759
The J30 having a lower R&P makes the gears longer in the sense of Speed. The 1st to 2nd shift dropping to 4krpm is gonna happen regardless because that has to do with the Transmission Gearing. If you would lengthen 1st gear, you could get more Speed from it which would then make for being at higher RPM when shifting into 2nd. The OS Giken kit is setup this way.Emperor_Tha wrote:I got the j30 diff 3.916 with 215/45/17 and it just feels like second gear is too long. When redline 1st to 2nd it drops to 4k. Making the car feel slugish. However I think first is too short, its just mash the pedal and then shift fast. 3rd and 4th gear feels pretty strong even at a 3k roll
if only it is safe to rev to 7500~7800 all the time in first then shift to second and be at roughly 4.5k . I think the powerband a lot smoother from gear to gear.DrifterProdigy85 wrote:
So to get the 4.36 R&P I need the diff out of a R32 GTS-T with the RB20, or a 89-90 180sx that had the CA18 in it? I found JHOT on ebay and will contact them this week. They also have very cheap prices on s13 silvia front end conversions. Thanx for the hookup. I shouldn't need the axels since I already have a 94 J30 setup?Tulsa_S-13 wrote:Maybe this will help
Correct.kentuckyslider wrote: So to get the 4.36 R&P I need the diff out of a R32 GTS-T with the RB20, or a 89-90 180sx that had the CA18 in it? I found JHOT on ebay and will contact them this week. They also have very cheap prices on s13 silvia front end conversions. Thanx for the hookup. I shouldn't need the axels since I already have a 94 J30 setup?
I dont know of any links that show the swap done but you will need the Diff from the Xterra (search the junkyards) and if it were me, id just take it to a shop to have the R&P pulled and installed in your Diff.kentuckyslider wrote:Drifterprodigy, I am going down to 24.5" tires with my 3.91 J30 R&P and that should help some at the drag strip but not enough. I run 265/35/18's on the street and autocross and it just leaves 2nd gear way to tall. I am going to wait until I get my cams and intake in and retune with and without water/methanol injection and see what my TQ curve looks like and where I peak HP at before I decide what to change my R&P to.
If you or Codyace could provide a link to the Xterra 4.60 swap I would appreciate it. I think that is were I will go. ThanxThe 4.36 jdm 180sx might also be a possibility? I know the 4.90 Xterra is out without 28" drag tires!
What R&P are you running in your car/what tires at the track? I would like to know a little more about your setup. With your MPH you should be running mid to low 11's with the right tire and R&P combination. 4.60 with a 26" tire will be a stretch if I change to a top mount GT3076 with meth and start putting down over 500whp. Wishful thinking, I know, but that is where I want to be when I get done with this car.........10.99@130mph..... surely it can be done?DrifterProdigy85 wrote:
With your R&P the 235/60/15 ET street radial is perfect for you. Trust me it is plenty of tire if the track is right. Run them at 18psi, do about a 5 sec. burnout, and launch at 6500-7000rpm and they'll hook.DrifterProdigy85 wrote:275/50-15 Tires with 4.363 R&P. I havnt ran on a prepped track yet. My run was on a grudge night with no VHT. Kept spinning off the line.
DrifterProdigy85 wrote:There BFG Drag Radials. My suspension is too stiff currently and ive only been once on an unprepped track. 2nd pass was a 1.91 60ft, did 12.06 @ 120.5mph. I was slipping the clutch from 5krpm and as soon as boost came on the tires would break loose to redline. Once i put the 50mm overfenders and stock suspension on the rear again, theres no doubt ill be in the 1.7 or so 60ft area. My tires choice is fine, its my suspension setup that needs tweaked now.
