Gear Oil
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
I picked up some Redline gear oil (wrong kind). Subaru calls for GL-5 for gear oil and rear differential oil. Has anyone used Mobil One synthetic or Valvoline Synthetic gear oil? I am thinking of going with Neo, but wanted some input on the other two gear oils.
bud
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I am running valvoline durablend GL5 (80w90) in my Q45 and I cant complain. Its good stuff, mobil 1 is good too but more expensive.
Cold_Zero
Are you running it in your rear differential?
elwesso
2007 BMW M Coupe
Yes. Running anywhere else would be bad news! :D
Mr1der
man gear oil stinks....
where's Fred at anyway?
BadMojo
Car: 2007 Mazdaspeed 3
Cold_Zero wrote:I picked up some Redline gear oil (wrong kind). Subaru calls for GL-5 for gear oil and rear differential oil. Has anyone used Mobil One synthetic or Valvoline Synthetic gear oil? I am thinking of going with Neo, but wanted some input on the other two gear oils.bud
Redline does make some GL5 gear oils. What did you pick up?
I've always had good results with Valvoline products, and as I recall, Fred always spoke well of their motor oil. Don't have any first hand exp. with Valvoline gear oils, though.
elwesso
2007 BMW M Coupe
I looked around for m1 and I could never find it... I run all valvoline products on my car..
Cold_Zero
The shop I went to gave me Redline MTL GL-4.
elwesso
2007 BMW M Coupe
GL-4 is 75w90. GL5 is 80w90. I dont see any harm by using that...
Cold_Zero
Well, the harm is in using something that the Manufacture does not recommend. I want to play it safe with the whole transmission.
Mr1der
go with the oem if you have doubts then, that way, if something happens, you can blame Subaru:D
BadMojo
Mr1der wrote:go with the oem if you have doubts then, that way, if something happens, you can blame Subaru:D
Actually, considering how strict some Subaru dealers are with warranty work (not personal experience, only internet hearsay), it wouldn't hurt to go with the OE stuff. I'd also keep every damn receipt you've got.
If I can ever find his cell #, I call my buddy who has a WRX and find out what he's running. Again, I've never heard anything bad about any Valvoline products.
Why hasn't anyone paged Fred yet? ;)
