gear oil
exdrift
Car: s13
is it ok for me to use redline lightweight shockproof gear oil in my rb20det trans
oneslow240se
Car: 91 240se
might want to try searching i the're a few that use em.. I just went with redline MT90
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
threadjack
how much oil should i put in my rb20 trsansmission?
bmadd2402
Car: Twin Turbo-shaft UH-60L, 1992 RB-240sx
as much as it takes. open the top plug, and fill thru the shifter until it comes out the hole. it is just over 2 quarts
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The best is to fill the transmission with a cheap ($6) plastic hand pump with the car sitting level. I tried squeezing thick transmission fluid through a rubber hose from the bottle and I haven't had a tougher forearm workout since. ...and keep your dirty little minds out of the gutter.
mello88
Car: s13
I'ma show u gangsters a nice trick that I was shown.. Darius you're gonna love this.
I made it for filling my diff but it works on trans just as nice. Less than $20 to build at Lowes/Home Depot/etc, and it'll take you less than a minute to fill your diff or trans up once you get the plugs out. Enjoy!
Edit: Some of you guys need to read the FSM more, and learn to work the search on here.. Not like we've never discussed oil varieties and fill capacities!!!
Shocker
Car: 89 240sxHB rb26/30
Darius wrote:The best is to fill the transmission with a cheap ($6) plastic hand pump with the car sitting level. I tried squeezing thick transmission fluid through a rubber hose from the bottle and I haven't had a tougher forearm workout since. ...and keep your dirty little minds out of the gutter.
Easier way, remove your shift boot, shifter, get a big funnel and pour it right in your shifter hole. Fast and easy. Just don't spill on your seats...
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
^+1 thats what I did!!!! Much easier...
exdrift
Car: s13
so can i use that oil
Shocker
exdrift wrote:so can i use that oil
yes I use the same stuff.
Sky80
Car: '92 240sx Fastback
+1 Redline Shockproof FTW!
