Gear oil question... Ive searched, and its taking more than what it said...
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Ok, so I am filling my transmission up with fluid now that I have my shaft in...
I did some research and got 3 qts of gear oil for my transmission, since it was supposed to take just over 2 qts... it took all 3 and still looks thirsty!!!
I removed the shifter and shifter plate thing and have been filling it up that way...
Should I just go to the store and get more until it starts coming out?
Josh
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
So you put your shaft in and you want to know if you should fill her up until it starts coming out? Well damn, I would say thats a discussion you need to have with her and not us! This is a pg-13 forum!
I put a little over 3 quarts in mine, about 3 and a half I would say.
Acecool
Yeah, just not thinking straight today ... I will head to the store and grab some more :-)
Just wanted to know that much, thanks :-)
S13 240SX
Car: 93 Mazda Miata
opps i put 4 qts in mine. lol
Acecool
Mine took just under 6 qts!!!!!!
lol...
And, she MOVES!!! MY CAR CAN MOVE!!!!!!
Shocker
Car: 89 240sxHB rb26/30
does no one search really? It seems like someone asks this very same question at least once a week.........
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
i thought its only 2 1/2 quarts. to much oil will cause alot of drag in the transmission
AxiOn419
Drove my car for a good while, first time out. The gearbox made a bit of noise, I may need more then 3.5qts.. Hmm, how much does everyone put in theirs?
Cjmartz2k
Car: Hunting for a '89 GTR now
3 quarts. I think it's actually like 2 3/4 or something, but I just stick 3 in. If you put the fluid in at the fill plug as designed instead of in the shifter, you can only put in 3 before it starts pissing back out the fill hole.
Are you guys serious about putting in 6 quarts?!?!? How does it shift? I grind a little and was just kind gee whiz wondering what putting a **** ton of fluid in would do.
Bwana
Car: Denali
If you put in 6qts I'm guessing you just filled it up to the shifter housing. It's only supposed to be filled to the plug in the drivers side of the case. If you seriously have 6qts in there you're going to blow oil everywhere when it gets hot.
Shocker
Bwana wrote:If you put in 6qts I'm guessing you just filled it up to the shifter housing. It's only supposed to be filled to the plug in the drivers side of the case. If you seriously have 6qts in there you're going to blow oil everywhere when it gets hot.
Doesn't matter, I fill 4 quarts into my shifter hole every time with no issues (rb25 trans)
For a safety check the car should be level, and the "proper" filler plug on the side of the trans should be removed, as soon as fluid starts to seap from this plug, shes full.
Acecool
Shifting is a little stiff, I havent really taken it anywhere though...
Thats why I asked heh...
Should I take the speed sensor out and train a little bit???
Josh
Acecool
Ok, smooth shifts when car is off, when car is on it is kind of hard to move into gear... reverse did not want to work at gas station...
So, open the filler plug until it drains out from there then it will be full?
Josh
AxiOn419
Err.. appears I have a gear oil leak from the input shaft area. That sucks. No telling how much I have leaked out. Hopefully it is a simple fix.
6qts does sound a little excessive, I imagine removing the filler plug and letting the excess drain out would be your best bet
Sky80
Car: '92 240sx Fastback
Yeah, you have a leak because you probably put too much in there, you guys are crazy, just take off the side plug see how much it takes to fill up, write down that number so that next time you fill 'er up you can just put it in the shifter hole and be on your way...
ryan15
Car: 1990 240sx
2.5-2.6 dudes thats it, your guys are nutts with 6 quarts.
Acecool
So, that huge bolt on the driver side of the transmission a little less than halfway up??
It is a SQUARE - How can I take it out??
Josh
garage-c
Car: RB25DET powered S14a
Remove it with a 1/2" drive ratchet... without a socket on it.
Acecool
Heh, dont have one of those, I went and got a crescent wrench!! - more work but hey, can use it in more places...
Going to do that now and will report back on how she shifts!
Acecool
UPDATE!!!!!!
Ok, so I took it off, drained about 3 qts... lol... and it shifts so smooth, no difficulty getting into gear = AWESOME!!!
Thanks guys
joelrgr
Car: 92 240SX
5 pints is suggested capacity. 2.5 quarts.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
never try to fill a miata trans through the shifter. opps he he
brndck
Car: getting crazy with the cheese whiz
6 qts? no no no no. 2.5.- 3 MAX!!!! you only need to fill it to the point where its level with the fill plug. (the square one on the side of the transmission).
Cjmartz2k
soooooooo.........
Basically what we said one month ago 5 times over then, right?
KoshiLe
Car: j.tran studios htx
AxiOn419 wrote:Drove my car for a good while, first time out. The gearbox made a bit of noise, I may need more then 3.5qts.. Hmm, how much does everyone put in theirs?
i put about 3.5 qt. I fill it through the side fill hole... just until i can stick my finger and feel it under the rim.
