Notice liquid seeping out of the drum and down the tire.
Took the drum cover off and it was saturated in what looked/smelled like gear oil.
Originally i thought it might have been brake fluid mixed with all the dust so i changed the pads and the wheel cylinder. Took it for a short drive. Still making the scraping noise.
Took it back apart and noticed more oil seeping out/collecting.Swapped driver side drum cover and tire/wheel. Still making the scraping noise.
So im convinced a seal has gone bad and gear oil is leaking. The following pictures are after i initially cleaned it/replaced cylinder/pads... and then it started leaking again on the short drive i took.
The most recent things that might have affected it..? I had firestone rotate my tires and immediately after i noticed and felt a faint clunking/click when jerking the wheel left to right.
I drove with the ebrake on the next day by accident for about a quarter mile at low speed.
I drove about 300 miles during tropical storm bonnie and unfortunately couldnt see all the puddles on the highway.. the truck went swimming through a few of them @ highway speeds.
Any idea what i am looking at here?
