Gear Issues and P0110 code
kene1001
Car: 1999 QX4 INFINITY
Two months ago, when I put the gear of my vehicle on drive (D) in the morning it takes so much throttling for a long time before the vehicle moves. It is now worse as the vehicle no longer move except you engage on (2) gear and drive for some time before engaging drive (D). Please can somone help with a solution.
Also, The P0110 code showed on the scanner and after replacing Intake Air Temperature Sensor, the vehicle idling improved but the code still shows even after clearing it. How do I solve this problem.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
On the first problem, check the ATF level in the transmission.
Chuck
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try following the diagnostic procedure on page EC-144 of the factory service manual to help diagnose your P0110 code.
And check the fluid level and condition as Chuck said above. Follow these steps to check the fluid properly:
1. Drive around for 10 minutes in the city after the transmission is at operating temperature.
2. Park on a level surface and apply the parking brake.
3. With P selected, shift through every gear and return to P.
4. Pull the transmission dipstick with the engine idling, wipe it clean, reinsert it completely, and read the level. It must be within the notched area labeled "HOT". Check for fluid contamination after wiping on a paper towel.
The fluid should be red, and not smell burnt.
