Gauges won't work after de swap :S
drft204
Car: 98 VW GTI VR6, 89 240sx Coupe
I put a DE Cluster in but i had to use the fuel gauge from the sohc cluster. nothing works in the cluster... the fuel is at the half way point even though i know that i'm almost outta fuel. my temperature gauge jus keeps going up everytime i turn the car on. when i start the engine the tach doesn't respond and i'm not sure if the speedometer works because i haven't installed my driveshaft or clutch line in yet and when i turn the light on theres no light in the cluster but if i turn it on then switch the key to the on postion, it flashes 5 times. i did connect the engine harness to the dash harness. but i have no idea why its not working :S
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
check your grounds
drft204
-RJ- wrote:check your grounds
damn don't remember seeing any loose "ground" wires under the dash if there were even any :S. does anybody know where they would be located?but i do have a couple wires that are cut... don't know if they're part of the gauge cluster though.
this picture is the center of the dash i didn't touch anything there. http://www.facebook.com/photo....01103
this picture is the driver side. didn't touch anything here either and i jus connected the buttons and switches for the headlights and dimmer and hazard.http://www.facebook.com/photo....01103
heres a closer picture?http://www.facebook.com/photo....01103
oh yeah did i forget to mention that it was jus an 89 shell. those were the only wires left in there and i didn't touch anything. the shells been passed around so yeah
-RJ-
you make sure there wasnt any frayed wires?
drft204
whats that?
-RJ-
broken wires, like cuts in the wires?
-RJ-
also are you sure that the cluster worked prior to installation?
drft204
pretty sure. it does exactly what the older cluster does. it flashes five times when i turn the key to the on position with the light switch on.
drft204
damn if the tach wire is the yellow wire with the red stripe(its the red wire thats visible in the picture) i see this connecter with it and i don't have anything on my engine harness to connect it to :Smaybe thats why my gauges don't work.
heres the engine harness connected to the dash though
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
just noticed RJ the "Racing Inspired Cosmetic Equipment " comment and fell to the floor..thats to rich
-RJ-
lol
