turtl631 »
https://forums.nicoclub.com/turtl631-u15171.html
Fri Nov 19, 2004 6:54 pm
Still doin some turbo KA research, and trying to figure out the most important gauges to run. I want a boost gauge for sure. AFter that, I don't know. I'm planning on some sort of ROM tune, so I don't need to monitor like I would if I were tuning myself. From what I've read, an EGT gauge is pretty pointless, since different combos of timing and AF ratio can result in hihg or low EGTs-meaning that its pretty inconclusive. I've also decided that an oil pressure gauge isn't too important since there is a stock oil pressure sensor/warnign light. Oil temp...same...shoudl be fine. This brings me to the water temp-my stock gauge is messed up, flutters always and drops to 0 once I give more than like 10% throttle (its weird, you'd have to see it). Also, I plan to hit maybe around 320-330 max on my setup, but stock radiator..so I guess cooling could possibly be an issue without extra ducting. Not sure on this, but it may be an issue. So, I figured a boost gauge and a water temp gauge woudl be more than enough for what I want to do. ANy comments?
