m30inaz wrote:......The fuses inside the car seem to be fine - I can't locate a fuse or fusible link in the engine compartment that might have blown.....
Same thing happened to me changing micro bulbs. Those little fuses can fool the eyes and sometimes the break can be so small you can't see it. Check the continuity/resistance of each fuse with a voltmeter. You don't need to pull the fuse, they can be tested in place quickly. If you don't own a voltmeter (< $15 at Radio Shack) you can pull each one and look at it with a magnifying glass.
Find the combination meter (AKA speedo cluster) in the electrical section (EL) of the FSM and there will be a schematic showing which fuses are in the circuit.
http://www.nicoclub.com/FSM/M/
Hint- It will take 30 minutes to locate the info in the FSM (good reading though!) and 3 minutes to check the fuses with a voltmeter. Do the VM check first.
Good luck
