IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Tue Dec 09, 2003 4:53 pm
oh, the ammeter is out of the question because an ammeter needs all the power in the car to flow through it in order to monitor current flow. basically, the car needs to be rewired so that the battery and alternator run through the meter. its not used in vehicles that have an alternator that pumps out more than 50-60 amps. yours probably pumps 85.
another words, its a racecar only type thing. dont even think about it, just return it.
a voltmeter is only measuring the electrical potential between positive and ground. there is no current flowing THROUGH it, its only monitoring. its less precise, but much easier, and safer. its also better to monitor the batterys state, and the alternators output.
car off- 12-12.5 volts- good 11.5v and below- weak/discharged battery.
car running- 13-14v good, car charging. 12-12.5v alternator weak.
now, the temperature gauge has a copper capillary tube with a sort of bulbus end?
and what kind of end is on the oil pressure gauge?
