Gauges in the dash???anything i should worry about
DawgMode
Car: 180sx
I wanna put like 3-4 gauges flush mounted across my dash on the passenger side but i was wondering be4 i drill my dash is there anything behind it that i should worry aboout???
DawgMode
Car: 180sx
any1???
90'240ka
You can remove you stereo console and stick your hand up there and check and see if there is any wiring harness's or something else, or take off you glovebox, or just take off your dash and be really safe about it, I dont have a 240 anymore , but hopefully this helps a little...
robbbby
Ya as ^ mentioned remove your glovebox.
adrock
Sounds like it could look pretty cool, but that's something I would plan REALLY REALLY carefully before I started drilling. I think removing the dash is absolutely necessary, because it would be a lot easier to make precise holes when you can see both sides of what you're drilling through. I don't mean to sound discouraging, but it would be really sad if you goofed and had a ruined dash. Good luck!
easymmkay240sx
Taking off the dash is an excellent idea, and not too terribly hard....plus, you're setup will more than likely be a LOT cleaner(wiring and aesthetically)
PGBrian
if you have a s14, you can drill right into the airbag. yeah!
yelnatsch517
Car: '95 Nissan 240SX
PGBrian wrote:if you have a s14, you can drill right into the airbag. yeah!
LOL or the compressed air tank right under it.
No but seriously, just look under the glovebox and you can see there is a bunch of stuff under there for an s14.
