Gauges-Electrical or Mechanical?
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
What are you guys running:Which is best for specific application(oil press, water temp, etc)Why to the above?Just for ideas
bcar240
Car: 1993 240SX HB
I just got a set of electrical gauges. It is personal preference really. But here are some simple +/- for both, others feel free to chime in.
electricalProsEasy to Install, run some wiresSlightly "safer" (no hot oil flowing in and out of cabin)
ConsRequires more wiring; sensor, gauge power, lighting (config differs on some gauges)Often come in only 90°-sweeps
mechanicalProsMore accurateLess expensive for full(270°)-sweep
ConsRun oil lines through firewall and inside cabin, better hope you got them tight.
slow s13
Car: cars, photo, music
I agree, electronic is a bit more expensive but they are easy to install, no oil lines in the cabin as stated before. I dont think any of us realy need a super accurate gauge most of the full sweep electric gauges should be very high quality. I have autometer cobalt series and am very happy with them the oil pressure gauge is awsome with the full sweep you can see the needle dancing even with the slight fluctuations of idle.
Thrwnsprkz
Car: 240sx
I have a electric oil pressure and a mechanical water temp... mix and match! mechanical is more accurate... but i dont want hot oil going to my cabin, water temp is easy tho... just a sensor
xero1
Car: 08 Altima Coupe
i have a boost and oil mechanical gauge, if you install the oil mechanical gauge right the oil line will not break. i use the nylon tubing kit. i looked at a electrical oil pressure gauge and a mechanical gauge, and the mechanical oil gauge responds faster than the electrical gauge.
spider_slayer
Car: S14 240SX
S13 240SX
is a super accurate oil pressure that reads the oil pressure in milli-seconds really nessicary?
justjuiceit4
Car: 1993 Nissan 240SXs, (Coupe and Convertible) 1994 Infiniti Q45
spider_slayer wrote:is a super accurate oil pressure that reads the oil pressure in milli-seconds really nessicary?
Mayebe. If your your oil pump chain broke, you might have a chance to cut off the motor before all you oil pressure was lost and possibly save your engine.
iliketocrash
highly doubt it.
slow s13
as I stated before my cobalt electronic is fast as shiz it has almost zero lag compared to all the other cheapo electronic gauges ive seen..sun pro and vdo
