GAUGE TEMP SENSOR LEAKING! any solutions or am i noob?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
Im in the process of replacing all sensors on this motor with new. the ecu temp sensor came with new copper washer. i installed that with no teflon tape,and its fine...no leaks. the gauge temp sensor has tape, but leaking and im afraid to keep tightening it, because i dont want to strip it. does this need a copper washer as well, because the old one didnt have one and it didnt take any force to loosen it.
should i use something else on threads? 5min job from hell
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Uuuh, maybe use more teflon tape? Its the temp sensor on the lower manifold, right?
boost_boy
splintercell wrote:Im in the process of replacing all sensors on this motor with new. the ecu temp sensor came with new copper washer. i installed that with no teflon tape,and its fine...no leaks. the gauge temp sensor has tape, but leaking and im afraid to keep tightening it, because i dont want to strip it. does this need a copper washer as well, because the old one didnt have one and it didnt take any force to loosen it.
Hope you didn't crack it or strip the threads because they don't leak and I've never put teflon tape on either one of the two sensors. Check and make sure there's no damage or that the sensor is ill-fitting.
Dee
splintercell
r34 gtr wrote:Uuuh, maybe use more teflon tape? Its the temp sensor on the lower manifold, right?
Its the one next to ecu temp sensor. the little one with male spade sticking out.
boost_boy wrote:Hope you didn't crack it or strip the threads because they don't leak and I've never put teflon tape on either one of the two sensors. Check and make sure there's no damage or that the sensor is ill-fitting.
Dee
threads look str8 i havent done anything excessive on it. sensor looks good too. does it need a copper washer like the ecu temp sensor?
boost_boy
splintercell wrote: does it need a copper washer like the ecu temp sensor?
No it doesn't. I've never seen one of them things leak. I just went and looked at all of mine and none of them are completely screwed-in. You may have to try teflon tape.
Dee
splintercell
LOL, it helps when you wrap threads in the right direction. i wrapped them 3 times and let it idle for 10min and boosted it a few times. she looks good to go.
thats what happens when your rushing on your lunch break @ work installing sensors in the parking lot. haha im still waiting on the rest of my valves & sensors from japan. the ecu temp sensor didnt help my idle any on startup either. i know its a culprit alot of times on most cars.
thanks nico crew for your help
float_6969
Teflon paste > Teflon tape (most of the time)
splintercell
float_6969 wrote:Teflon paste > Teflon tape (most of the time)
a local mechanic recommended the same thing. i drove it all night and checked it @ random locations and she was good.
