gauge problem
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
snakecbaker
Car: 1985 nissan 720 king cab 2wd
my temp and gas gauge just stoped working a few weeks ago they would work then stop and then work it acks like a loose wire but now sure the speed , oil pressure, and volts all work fine if you have a guess what is the problem let me know iam new to nissans
Aven
Car: 84 720 Kingcab
Best guess, a ground is causing your headaches.
snakecbaker
if its a ground were would i find it
Aven
Car: 84 720 Kingcab
The ground to the gas gauge come from the float and out of the tank. Check this thread. zerothread?id=475725
There is a ground off the temp sending unit. Look under the thermostat.
If these aren't you problem then it might be your instrument cluster.
snakecbaker
thanks for the help iam going to check the grounds today iam hoping its not the cluster parts are hard to get in wv for the 720s
snakecbaker
THANKS for the help i found the problem it was the ground to the block i was serprized that it still ran with it off. i hooked it back up and my gauges started working.
Aven
Car: 84 720 Kingcab
Great. Glad to hear it wasn't the cluster.
Return to “Datsun 720”
