Gauge Pod!
Nismo-S14
Car: 1995 Nissan 240sx SE S14 sr20det,1991 Nissan 240sx Coupe
just to let you all know i have searched, I Have a 95 240sx and i'm going to install a piller pod. And my question how do i run the wiring to the piller for my gauges, do i have to pull a part the dash or is there an easier way, and i did read the instructions but didnt give me much to work with. So any info helps thanks.
Morph
Car: 91 Sr Powered Coupe
What I did is i took off the pillar and then got some thick wire and ran it down between the dash and the pillar and fished it out of the bottom. Tied some string to the wires for the gauge and to the thick wire, then pulled the thick wire out of the bottom and your done.
Nismo-S14
yeah thanks for the info that help alot i finish the pillar pod last nite came out clean thanks again
Hijacker
Car: '92 240sx Convertible
'94 F-150
Moving to 240 tech
Morph
Nismo-S14 wrote:yeah thanks for the info that help alot i finish the pillar pod last nite came out clean thanks again
Pics???
Nismo-S14
i would but i dont have any idea how to post pics.
