Gauge pod info??
Saloon
I currently have a 90 240sx coupe, and am currently in the process of installing gauges. I have an Autometer AutoGauge 2 5/8 boost gauge, and my question is...Is there a company who makes a A-Piller pod that houses a 2 5/8 gauge for the 240? Even if it's a single pod, dual, or ever a 2 1/16 on top and 2 5/8 on the bottom which would be the preferred setup? I have looked in the autometer catalogs and they don't list anything, and if it happens that there is NO company that makes a 2 5/8 a-piller pod for the 89-94 240, are there any other pods that could possibility retrofitd to work? Thanks for your time...
Saloon
Scott McLellan
Maybe you could buy a 2-5/8 tach pod and mount it somewhere.
allthrottlenobottle
Car: 91 s13
Hey saloon. I have a 91 but i have 2 1/16" gauges but i think i got your solution. "Gauge Works" makes a 2 5/8" single pod for a 96-01 civic . I had to buy a dual 2 1/16 for the same years and i took my trusty heatgun and molded the pod a little better to the oem a pillar. Gauge Works may make the piller an oem replacement but you could probably modify it easy enough. VDO also makes a single 2 5/8 gauge pod in the more traditional abs plastic style but it is molded for a 79-93 mustang so i dont know if you could modify it. hope this helps. If i find out more i'll let ya know.
