BuddyGuy »
https://forums.nicoclub.com/buddyguy-u21049.html
Mon Oct 18, 2004 1:46 pm
Yep.. it was the dimmer switch....
After looking at Michells electrical schematics, you can easily see if you touch the two illumination wires together, it would create a short, causing the dimmer switch to burn out.
Thanks much.
Also on a very important side note,
The illumination in the driver's side power window button, the one marked "AUTO" is not connected to the dimmer circuit and has a seperate ground.
So in short, if you "AUTO" is lit up, but no gauge lights, then its most likely the dimmer switch and not a fuse.
Modified by BuddyGuy at 4:59 PM 10/18/2004
